Browse Forums Bathrooms and Laundry Re: Instantaneous HWS req certain pressure to maintain hot water 15Feb 24, 2010 2:25 pm vvs mand Im guessing its something to do with the unit not likeing your flickmixer. Looks like you hit the nail on the head. Had a chat with a bloke at technika technical support and he asked if I had low pressure taps fitted. He lost me in the jargon but I recall 30kPa or something like that and normal tapware not being suitable for use with the unit. I'm going to get the plumber to speak with technika and resolve it. See where I get. First time building 2 storey home, is under construction (in Framing stage) in NSW. I have 3 toilets and need bidet spray in… 0 16852 the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 14030 |
