Browse Forums Bathrooms and Laundry 1 Feb 11, 2010 4:33 pm Hi I would like to remodel my current bathroom and toleit into two small bathrooms. However, one builder mentioned that the waste pipe from the new basin cannot be put undergroud because it would need to dig into the concrete block base that might raise structure concern. In other words, the pipe will be seen on the ground when the job is done. Is that true? Do you have the similiar issue and what's the solution? thx Re: waste pipe on the ground? 2Feb 11, 2010 8:50 pm yyh Hi I would like to remodel my current bathroom and toleit into two small bathrooms. However, one builder mentioned that the waste pipe from the new basin cannot be put undergroud because it would need to dig into the concrete block base that might raise structure concern. In other words, the pipe will be seen on the ground when the job is done. Is that true? Do you have the similiar issue and what's the solution? thx Hi, I think he means that he would have to cut a trench into the concrete slab inside the bathroom if you wanted the waste pipe totally hidden. Not recommended. If the new vanity is against an outside wall he will place the waste pipe out through the wall, where it will turn down underground immediately. That is very common. I believe sewage waste pipes can't be routinely laid on-ground, they must be protected somehow. Anyone know about that? If the new vanity is not against an outside wall there will indeed be a difficulty. We have two such in upstairs bathrooms, and under one in the kitchen the waste pipe is hidden by a false ceiling on its way outside, and under the other in the laundry it is visible, running across just under the ceiling. We forgot about it after the first week or two. Cheers Re: waste pipe on the ground? 3Feb 12, 2010 2:43 pm Thanks a lot, GeoffW1. Unfortunately the new basin is not against an outside wall. Can I ask the reason why it is not recommended to cut a trench into the concrete slab inside the bathroom? After construction, it would be two small bathrooms in my single-story house. That's why I worry whether it would look ugly/unconvenience if the pipe sits on the ground even though it is protected. Thx Re: waste pipe on the ground? 4Feb 12, 2010 3:19 pm yyh Can I ask the reason why it is not recommended to cut a trench into the concrete slab inside the bathroom? Structural integrity of your slab ? Cost ? Built a Tribeca 44 with the Big M Sales Accept 15/06/09, Contract Signed 24/09/09, Site Start 23/11/09, Slab 11/12/09, Frame 12/01/10, Roof 20/01/10, Lock-up 30/03/10, Fixing 30/04/10, Handover 27/08/10. Re: waste pipe on the ground? 5Feb 12, 2010 7:06 pm jimmalenko yyh Can I ask the reason why it is not recommended to cut a trench into the concrete slab inside the bathroom? Structural integrity of your slab ? Cost ? Hi, Yes, that's it. In a slab bearing the loads of the roof, brick walls, and any upper stories, stesses tend to deflect it especially near to weight bearing walls. Trenching will compromise that. Also in your slab will be reinforcing steel which requires a covering of concrete to protect it against corrosion. Trenching will expose this, and it may have to be cut. In a forum like this one I could not say anything but "not recommended". What about an unobtrusive box-section ledge running along the wall-floor junction, hiding the waste pipe on the way to the nearest wall? Another, somewhat over-the-top possibility is a complete false wall, installed just to hide the waste pipe!! Cheers Re: waste pipe on the ground? 6Feb 16, 2010 7:44 pm Thanks guys. I am new to bathroom renovation and thus still learning... In thread 'Yay - ensuite renovations... Nearly done!!!' viewtopic.php?f=21&t=15633&start=0 It seems it cut up the concrete to put the pipes down. That's what I originally thought the pipe would be put in. Could it be applied in my case? Will it take a lot of money to get it done in that way? No offense. I just would like to find the best solution as I could before it really starts. Thanks again. Hi everyone, Looking for some advise. We are about to build an above ground pool in our backyard. There is a private sewer line running under the pool at 1.6m… 0 11757 Hi, I'm new to this forum so I hope I'm doing this post correctly. Please advise if it's not. I've just bought my place. The inground pool has a marble lining that has… 0 13662 |
