Browse Forums Bathrooms and Laundry 1 Jan 23, 2010 4:19 pm Has anyone extended their wall (reduced the size of their bathroom) in order to gain a shelf above the vanity and below the mirror cabinet. Eg. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Is that how it actually works? As in you need to reduce the size of the room? Would love to see some more pics preferably during construction stage if possible Also, is this a must if having a cabinet above the vanity? As in if the vanity is too low and is obviously sticking out you might hit your head when washing your face for example. Correct? Re: Extending the wall in order to gain a shelf above the vanity 2Jan 23, 2010 5:24 pm It would be the same principle as the feature niches we have - the wall frame is simply thicker than usual, allowing for a cut-out area. I think it's a great idea where you have the type of basins that are wall-mounted (i.e. no vanity). If you already have a vanity with adequate bench space it seems unneccesary, although it does look nice -and you'd have extra storage/display space. The second pic looks as though it's been done purely to mount lighting in there - there's already a bench top, plus that appears to be a row of shaving cabinets with mirrored doors, so there's plenty of storage space. The lighting wouldn't be useful for putting on makeup etc, either, it's too low. Decorative feature only, I guess. Re: Extending the wall in order to gain a shelf above the vanity 3Jan 23, 2010 6:55 pm kek It would be the same principle as the feature niches we have - the wall frame is simply thicker than usual, allowing for a cut-out area. Ahhh. I also want nices in all our showers but thought that there is no insulation in that part of the wall. Didn't realise that the whole wall needed to be thickened... Thanks for that! Re: Extending the wall in order to gain a shelf above the vanity 4Jan 31, 2010 2:21 pm Not very popular on this forum I guess If your patio is going to be 35 sqm then that's going to need Council Approval. The fact that they previously approved your 25sqm patio will be irelevant 1 5494 Ask for some kickplate to be added and also for tradies to be requested to use lanyards on tools on that side of the building. Be respectful and have the discussion… 1 1671 There is insufficient information to give a meaningful answer. You should talk to council planning. Apart from building construction issues, if you are adding floor area… 1 7971 |
