Browse Forums Bathrooms and Laundry 1 Oct 25, 2005 12:20 pm Just wondering what sort of life span one could expect out of a tile/glass cutter bit for an electric drill? We just drilled two holes through our tiles last night to mount the toilet cistern and the drill bit is absolutely buggered. Don't think we'll get another hole out of it - and considering these bits come in at the dearest drill bit around I don't think you get your money's worth out of them. Re: Tile/Glass Cutter 2Nov 15, 2005 8:50 am Hi I use a spear tip also you might want to use it with water I just get a cup drill a little dip it in the cup of water and keep going trick is to not let the drill bit get hot hope this helps you Looking for advice on whether this variation in tile colour is acceptable. The large tile on the left was used in my main bathroom renovation 1 year ago. My ensuite… 0 8574 Hi Kaiser85, We are building with Firstyle Homes. Our build has just started, slab pour is on Saturday (hopefully!). Their standard range is pretty good. We did our… 1 6576 |
