Browse Forums Bathrooms and Laundry 1 Nov 17, 2009 1:21 pm Hi all, Hoping one of you clever plumbers can assist with an issue we're having with a Grohe Eurostyle basin mixer. Our plumber is fine at putting together all the parts to install this however once put together, the mixer handle is "wobbly" over the internal diverter joint (if you get my meaning). It seems like it is missing some sort of attachment which would make it firmly connect to this joint. Otherwise the handle would be connected very loosely to the wall. Is someone able to help? Thanks so much. Virginia. Re: Problem installing Grohe basin mixer - help! 2Nov 17, 2009 8:12 pm So its the whole handle that wobbles? Has the grub screw been done up? Should be a hole under the lever part of the handle, lift handle into on position and you can see a grub screw. Should only need an allen key to do it up. Possumchops Now the proud owner of 3.7acres of Serenity. Colour selection completed! Soon to go to council. Re: Problem installing Grohe basin mixer - help! 3Nov 18, 2009 12:24 pm Tks Possum, yes the grub screw had been done up, we worked out there was another part missing which will fix it, they are sending it out for us so all is good. Virginia Hi everyone! This is my first time posting here, and I'm looking for some advice regarding my house construction project in North Kellyville. I… 0 6701 Ask yourself if the insurance company will be aware of the Reno. 4 7382 Hi l plan to install a self adhesive vinyl plank floor. l first need to attach masonite boards underlay to by plywood subfloor of my house. What size nails and how many… 0 8378 |
