Browse Forums Bathrooms and Laundry 1 Nov 19, 2009 1:22 pm Hi there, My current unit has a small electric hotwater tank under the sink in the kitchen and am looking to upgrade to a continuous hot water system. My options are to either get an electric one or switch to gas as we have that in the kitchen too which we'll use for cooking. Has anyone had any experience with continous electric hot water or have they switched to gas and if so what is required ? Thanks! Thanks good to know. How big is your tank? So you can set when your heat pump runs? How do you do that? How's the speed to heat? Is there such thing as instantaneous… 4 990 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20232 the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 14059 |
