Browse Forums Bathrooms and Laundry Re: Loud wistle noise from cold copper pipe 4Dec 03, 2009 10:41 pm Hello Check to see if the plumber has installed mini stop cocks underneath your basin. In the past there have been a few brands that have a small spring inside them that make a noise when water runs through it. These mini stop cocks are usually 1/2 or 1/4 turn taps with a small handle. The only way to fix it is to remove the stop **** and replace it with another brand. Common problem and it does happen with toilet cisterns as well Regards Shane DIY, Home Maintenance & Repair We have a hot water copper pipe that runs from our hot water unit on one side of our house under a concrete slab to our bathroom and laundry...old house so not ideal. The… 0 5116 Ain't that the truth! We used to have a tile roof and had it replaced with colorbond and suddenly everything throughout the entire house sounds louder! 4 6703 Depends how much direct sun it gets. Is there any shading (eaves or trees)? If the sun hits a window directly it doesn't matter too much if it's double or single… 1 12671 |
