Browse Forums Bathrooms and Laundry Re: installing a toilet bown on slab floor 2Nov 13, 2009 9:25 am Best you ask a plumber... I won't be fun. Where you are coming from is where you are going to... Re: installing a toilet bown on slab floor 3Dec 03, 2009 10:56 pm Cheapest way is to install the toilet facing the external wall. The plumber would install a p trap pan and run the waste through the wall, instead of running it in the slab which costs big money. Hope this helps Regards Shane Re: installing a toilet bown on slab floor 4Dec 06, 2009 9:23 am Some good advice already given by previous posters The biggest problem is that laundry drain pipes usually aren't large enough to allow for toilet type waste. Depending on your plumbing layout this may require extension of the sewage pipe to the laundry location. If you can't mount the toilet on an outside wall as suggested above and you don't want to tunnel through the slab you could look at installing one of these. www.saniflo.com.au/ There are other manufacturers as well, this is just the first one on Google. I have a toilet that blocks up on the top (2nd) floor of a property. The toilets on the 1st and ground floor are OK) Blockage clears when the using a plunger. But… 0 500 Hi everyone! This is my first time posting here, and I'm looking for some advice regarding my house construction project in North Kellyville. I… 0 6701 Ask yourself if the insurance company will be aware of the Reno. 4 7385 |
