Browse Forums Bathrooms and Laundry 1 Nov 10, 2009 3:39 pm Hi there, I'm looking for someone to do rendering in two bathrooms to prepare for the tiler (the walls are pretty rough after old tiles came off). The job is in Caulfield South. Can anyone recommend a good (not expensive) renderer? Thanks in advance. Is it possible to render an old corrugated iron shed.I have heard that it can be done if it is covered with chicken wire first.Not sure of the ratio of the render mix and… 0 4898 Dear Members I have to decide the Facade column size. My custom builder standard is 350mm with rendering, but i asked for 470mm plus stone or tiles and yet to get… 0 7508 yep you need a joint, foam is easiest, will look fine once rendered with a joint. 2 5243 |
