Browse Forums Bathrooms and Laundry 1 Nov 02, 2009 1:50 pm Hi I'm not sure if the terminology is correct, but I have a framess glass shower enclosure, that just sits over the tiled floor. On the bottom of the door is like a weather strip, that just helps prevent water escaping out of the enclosure. The strip has basically worn away, and i'm not sure what to replace it with, or where to find it? Anyone able to help? Many thanks Neil Re: Shower door - replacement "edge strip" 4Nov 04, 2009 12:45 pm mac64 Cheers mac - that's brilliant! Just what I was looking for. Many thanks Neil Hi everyone, Just wondering if anyone has switched from a small square tile insert or normal square waste to a strip drain at all, and if so did the plumber or diy-er… 0 13128 Just be careful with building stability during construction, that is when the structure may be weakened, refer to your engineering drawings for stability methodology. 1 7215 |
