Browse Forums Bathrooms and Laundry 1 Sep 01, 2009 9:46 am Hi I am having a 150 cm vanity installed with one basin in the middle. I still need to pick the mirror size. What is the most common in mirror sizes for a vanity this size? I personally don't really like the full width look, plus it will be very tight fit with power points/light switches between the mirror and the door frame. So I am leaning towards 110-120 cm width. BUT what height? it will be sitting about 15cm above the vanity benchtoop to avoid too much water splatter (needs cleaning) Jack Re: Bathroom mirror size 2Sep 01, 2009 3:00 pm It depends on personal preference really, plus maybe your ceiling height would be a factor. Do you want the mirror to go all the way to the cornice, or stop short? Our ensuite mirror goes to within about 2cm of the cornice, but the one in the kids' bathroom is lower - it matches the height of the tiles in the shower. And just a thought - a bigger mirror will make a small room appear larger. Re: Bathroom mirror size 3Sep 02, 2009 4:44 pm Personally, I would have thought the most common mirror size for that sized vanity would be a full width mirror. Any chance you have a pic to show the light switch positionings .. maybe just end if short of them, but equally on either side. I would make it as wide as you can .. I always think the bigger the better with regards to mirrors and vanity ... but that's just my opinion (Good luck .. always so many decisions to make ... try having a look online at display homes and see if anything catches your eye. Some have bulkheads fitted above the mirror with down lights ... lots of ideas, it's just finding what you like and want to live with. Re: Bathroom mirror size 4Sep 22, 2009 12:38 pm My mirrors are measured to size. My width is the whole length of my vanity and the height is to the window frame level. Dear Members I have to decide the Facade column size. My custom builder standard is 350mm with rendering, but i asked for 470mm plus stone or tiles and yet to get… 0 4299 All sorted guys. Just needed to buy a blade with the correct bush. Dunno how to delete this post, can't find any help file. Cheers. 1 2821 Current door width is approx 2700, looking to have double doors fitted 820-820. What size does the frame need to be before door jamb? Thanks 0 2328 |
