Browse Forums Bathrooms and Laundry 1 Aug 17, 2009 2:13 am Anyone got a few ideas what I can do to with feature tiles for this shower? I was going to do 2 rowes of scored tiles down. But now Im thinking what about 1 row horizontally. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Any help would be great. Thanks KW............. “It's just as unpleasant to get more than you bargain for as to get less” George Bernard Shaw. Re: Any ideas for a feature tile for this shower, please? 3Aug 18, 2009 10:18 am The vertical scored idea looks better but means a lot of grout at a lower level which will be in contact with water. Are you tiling to the ceiling? One option may be a partial vertical panel. Use you scored tile to encompass say you taps and shower head and make sure it is equal distance below and above them. This way you can say start your panel say 400mm off the floor and carry it above the shower head. Works real well if you tap ware and head are all centrally located on the panel - and looking at you pic it may work real well as its even central on that wall. The other way is if you can introduce a nieche in the wall use the scored tile there. Once agian it highlights the nieche and is away from the majority of water. Charlie Re: Any ideas for a feature tile for this shower, please? 4Aug 18, 2009 10:47 pm Hi all Thanks kindly. Yes, the neich sounds cool and would be a feature itself. My concern is the cost they will try to charge me IMPO your bathroom can be a real show peice of your home. Its the only place you cant hide poor colour choices with nice furniture, like a nice lounge or rug, so you have to work a bit harder to get it right. Helps to have good friend on the forum to point you in the right dirrection, thanks. Regards KW.......... “It's just as unpleasant to get more than you bargain for as to get less” George Bernard Shaw. I had an old shower unit that broke on me and when I took it off, there were only 2 water pipes, instead of the normal 2 water pipes and a shower head pipe. S o I… 0 36939 A question. Im in Queensland and building a new home. We managed to reach practical completion 6 weeks ago but we haven't heard any date for handover yet. Who should we… 0 5807 i had the my concreters concrete right up to the fence. I have pits all along my path, so the water tends to drain away from the house and into the pits. There's only one… 7 12773 |
