Browse Forums Bathrooms and Laundry 1 Aug 05, 2009 5:24 am Hi Can someone please tell me how to cut a slanted line between tiles. Because my floor and the celing is very uneven. I perfer not to buy a power equipment as I only have around 10 tiles.. are there any manuel saw for this kind of work? thank you Re: Newbie on cutting tiles..please help 2Aug 05, 2009 8:02 am Not quite with you there bikey... Onc_Artisan Where you are coming from is where you are going to... Re: Newbie on cutting tiles..please help 3Aug 05, 2009 8:24 am diamond tipped grinder is the only way to create intricate cuts, you can buy a grinder for well under $ 50 (cheap but will do what you want). If you don't have much experience with power tool, go easy this is one tool that will give the in-experienced a shorter finger or two........ so be careful. Depending on your tiles, you can use a glass cutter and nibblers to create a freehand radius/shaped cut but i bet you mess a few tiles up this way. The pro's use a grinder, that says it all..............good luck anyway. Re: Newbie on cutting tiles..please help 4Aug 05, 2009 8:34 am My second favorite tool innovativeGLASS Onc_Artisan PS first is knowlege Where you are coming from is where you are going to... a building inspector should be able to tell you about any major problems but we need a floor plan with dimensions to clarify options for extra bedrooms ... sometime an… 1 8727 Thankyou so much 😀 I've decided on White on white for doors and trims, White on white 50% on ceiling and Mt buller for walls. Fingers crossed it will look OK 😀 2 7170 i had the my concreters concrete right up to the fence. I have pits all along my path, so the water tends to drain away from the house and into the pits. There's only one… 7 12786 |
