Browse Forums Bathrooms and Laundry 1 May 26, 2007 2:03 pm I intend to replace the 30 year old mirror in my ensuite. It seems to me that the existing frameless mirror is glued to the wall (probably of fibro-cement sheeting). It has been suggested that I use a length of wire to pass behind the mirror and cut through the adhesion. Any comments/hints would be appreciated e.g. what type of wire, safety aspects, how do I easily remove residual glue ![]() ![]() Re: Wall mirror in ensuite 2May 28, 2007 2:42 pm Michael, I've only tried to do this once with a newly installed mirror - without success.
There are various 'wires' to try including a coated cutting wire but I would be inclined to first speak to a glass/mirror mob to get some first hand tips. Being such an age the glass is going to be very brittle & easy to crack. Peter Clarkson - AusDesign Australia www.ausdesign.com.au This information is intended to provide general information only. It does not purport to be a comprehensive advice. Re: Wall mirror in ensuite 3Jun 01, 2007 8:31 pm Thanks. It turned out that the mirror was not glued in its entireity - it was held onto the wall by adhesive strips. The cuttting wire was successfull. Thanks for the suggestion. The space between shower and sinks was too tight. I agree about the toilet location. So I have tried two other options: The lower one is… 3 2865 the step up is 30mm and wanting it to be flat . how much does the concrete have to be lowered .we plan on removing bath and lenghten shower and adding seat. the old bath… 0 5878 Not unless it comes under the overlooking rule, but being at the front, I doubt you are overlooking anyone's private space. So no. 1 1954 ![]() |
