Browse Forums Bathrooms and Laundry 1 Jul 27, 2009 1:20 am HI EVERYONE, I am a newbie on the block and I have to say this is the most practical forum I have come across. Any way, I have a high set house and would like to make a separate unit downstairs. It has a toilet wash basin but no shower. I would like to use a small bedroom to convert to shower and laundry. I have a water tank not being used which I would like to use with bottled gas for this and a kitchen which needs to be put in. I would like suggestions on stretching the mighty $$$$ with bottled gas with tank water, shower cabinet, kitchen with gas appliances. I have space downstairs that I would like to renovate to bedrooms a lounge and kitchen any help would be gratefully accepted. THANKS in advance. If you can calculate the reasonable charged head from let's say 100mm below the gutter to the top of where the vertical riser's horizontal discharge pipe will be, that… 11 17707 Building Standards; Getting It Right! Thank you for the generous offer. I need to get the plumber out to give me an explanation. As mentioned I haven't seen any rain water discharge from pipes 1& 3. It… 7 11023 Can a plumber put a tap on a rain water tank which is full? Tank is similar to one in photo. Cheers. 0 1767 |
