Browse Forums Bathrooms and Laundry Re: Different colour schemes for bathrooms within a house 10Jul 23, 2009 8:38 pm Ours have the same colour scheme - we wanted a consistent flow through the house, so repeated several colours and finishes to tie everything together. I differentiated them slightly by using different feature tiles, and we have different towels and accessories in each. The laundry has the same base cabinets and benchtops as the bathrooms, and same floor tiles, but different wall colour and splashback tiles.... so everything isn't identical, but there's a theme. If you have all ensuites, then coordinating them with the bedrooms they're attached to would make sense. There's no right answer, it's like most things with building: it comes down to what you like. yep you need a joint, foam is easiest, will look fine once rendered with a joint. 2 5243 Hi, have purchased a house with 2 single garage doors. The Centre pillar one side sits proud to the other. Can I change 2 doors into one. Please see picture. 0 6357 Hi All, This is our second home build and first time with a custom builder. They are small builder and have built some houses with good quality. They tender and color… 0 608 |
