Browse Forums Bathrooms and Laundry 1 Jun 26, 2009 12:12 am hi I have an old barthroom thats all fribro and we need to know what elce to do the walls in or is fribro ok and how do you make it all water prof and what about all the old mold how do u stop it is it by replacing all the old fribro Re: Old barthroom our first DIY 2Jun 30, 2009 10:33 am Hi there Dandi, I guess depends on your budget, if you have one set? Best would be to do a renovation.. For the walls, you would replace them with Villaboard an either waterproof it yourself, or call a waterproofer. Waterproofing, there is many products, a lot of people argue against what is best, what is not etc.. etc.. cost also. I personally have used them all.. have seen most of them fail to an extent.. but would recommend Dampfix 2.. Here is a link with how it's to be used etc.. http://www.tilersonline.com.au/files/file/ASA%20Tile%20Adhesives/D/DAMPFIX2%20SHOWER%20REP.pdf Once you have done the 2 coats, you are then able to tile the floor & walls or get someone to do them.. (tilers usually have a license to do waterproofing also) Where is the old mold?? if on the ceiling, you can use bleach to treat it, then you can re-paint.. If you have some photos, be sure to post them up, will help people to explain steps, an what can be done etc.. Cheers Mano Re: Old barthroom our first DIY 4Jul 03, 2009 2:18 pm How old? Bathrooms are apparently a common area to find fibro sheeting that contains asbestos, and that has the potential to make things far more complicated if you want to do a full renovation. If you want to fix specific problems with mould and leaking then it may be useful if you provided more details. Assuming the structure of your cabinetry is good then I would DIY everything as follows: - replace your counter tops entirely, - replace all drawer runners with soft close… 1 4782 Re my second point – yes exactly. And often it may take additional time if the manufacturer recommends no more than X meters… 3 5642 |
