Browse Forums Bathrooms and Laundry 1 Jun 16, 2009 12:16 pm Hi guys I have a big 1.3 m x 1 m mirror stripped off from an old big dressing table, the mirror is in good shape but as it was taken off a timber frame it has raw edges. now- 1. How do i fix it on the wall- the bathroom wall has ceramic tiles been there about 10 years. 2. How do i unsharpen the edges. ? do i take it to a galvanizer or can i use a small hand held electric disc grinder? Thanks heaps in advance. Mat Re: Frameless mirror- how to fix it to the wall in bathroom abov 2Jun 16, 2009 10:02 pm Gday You can buy a drill bit from Bunnings to drill into tiles but put some masking tape over the area where you are about to drill so the bit stays in one area as it will tend to slide all over the shop without it as the surface of the tile is normally quite glossy and slippery. Dont use too much pressure just let the drill bit do the work. Too much pressure will cause the tile to crack. Remember when you are looking at a location try and make sure the holes you are going to drill are away from the edges of the tiles to avoid breakage/chipping. Use the appropriate hole plug for the type of wall you have, brick,concrete,stud wall etc. You can also buy a crome 4 piece mirror mounting kit from Bunnings. It basically fits to the wall, you slide the bottom of the mirror into the 2 brackets on the bottom and the top brackets are spring loaded and you slide them up to allow the top of the mirror to fit in against the wall. The edges will need to be ground down by a glazier, unsure of the cost but check first as it may be cheaper to buy a new mirror with that part already done. I know mirror glass is quite cheap. I assume you have a bunnings store in whichever state you are in. Hope this helps. Slugger.. DIY, Home Maintenance & Repair Ditto 3M Claw, expensive but best thing I've used to date. I put two of the 11kg ones in for a 12kg mirror on the wall, and its been great for 4 years now. 4 2143 I recently went through a similar renovation and move scenario when updating our family home. We also swapped some rooms around and tackled a major… 2 10033 2 4496 |
