Browse Forums Bathrooms and Laundry 1 May 22, 2009 11:51 pm So most people prefer CS in kitchens, but what about bathrooms? Same? What types of benchtops perform best in very wet conditions? Re: Popular bathroom benchtop choices 2May 23, 2009 8:09 am I have always had laminate benchtops in my houses and have never had a problem. In the rental I had in Brisbane they had stone and that wasnt a problem either. The only difference I found in bathrooms and kitchens is, with stone it feels (obviously) a lot harder when you place things ie dishes on there and it is a lot noisier when you do this. I prefer Laminex for my benchtops because of this as when serving meals etc the kitchen had a lot of clanging noises with the stone, Laminex seemed to absorb a lot of the noise. I prefer the look of stone but prefer the feel of laminex Know where your going in life............... you may already be there Hi Courtney The mitred edges are glued up with epoxy so those little holes and gaps are areas that weren't filled correctly. Silicone is the wrong product to fill them… 2 12933 Render your bathroom walls, two opinions versus the one, makes you wonder. 3 6105 Hi Geoff Install Puddle Flange prior to any screed. Puddle flange needs to be flush with the surface so you may need to grind away the surface to achieve this. Also as… 2 8407 |
