Browse Forums Bathrooms and Laundry Re: Shower niche or shelves or baskets 23Sep 23, 2014 9:12 am Where did you get that shelf from Splashers? Our Build: viewtopic.php?f=31&t=72518 Re: Shower niche or shelves or baskets 24Sep 23, 2014 10:29 am The shelf has been built into the wall at the framing stage, than waterproofed using Crommelin Waterproofing which is a good thick flexible membrane with all edges and corners re enforced using the fabric so the corners will not crack and cause a leak over time. Than simply tiled using feature tile and for the flat surface we used the floor tiles as they are larger and easier for water to run away, the shelf has a slight tilt on it but you can not notice it. Re: Shower niche or shelves or baskets 25Sep 23, 2014 12:30 pm Ahh i see.. Well im still researching where to buy glass shelves without the silver bits oxiodising. Any feedback would be much appreciated! Our Build: viewtopic.php?f=31&t=72518 Re: Shower niche or shelves or baskets 26Oct 10, 2014 9:51 am I know that some of the larger builders charge around $800 for a niche. Basically. If the shelves are fixed then they will be screwed in just the same as the rest of the carcass. To re move the screws you need to remove that section of… 3 5200 I'll look into different shower heads and ask the plumber about some engineering and see what he says. Thanks 2 9563 Hi All, about to commence a bathroom renovation and need some advice on subfloor works. Current subfloor is hardwood T&G floorboards on 90x45 joists, but intention is to… 0 5834 |
