Browse Forums Bathrooms and Laundry Re: Noob renovating bathroom 31Mar 26, 2009 8:24 pm Built with Bentley homes in Doreen All moved in Dec 2009 Now for the garden! Our stuff so far viewtopic.php?f=31&t=16532 Re: Noob renovating bathroom 33Mar 26, 2009 8:57 pm Built with Bentley homes in Doreen All moved in Dec 2009 Now for the garden! Our stuff so far viewtopic.php?f=31&t=16532 Re: Noob renovating bathroom 35Mar 27, 2009 4:56 pm The waterproofing done after the walls are lined removes any need for metal angles in the corners etc. I used a Marbletrend solid base which is checked directly into the studs, for this reason I had to waterproof in behind the base. http://www.marbletrend.com.au/cms/pro_sheets/MT_install_37.pdf If you are tiling the floor there is no need for it http://www.jameshardie.com.au/products/villaboard.html What you are looking at is fibrous plaster, true gypsum, it is cast on horizontal beds with fibers included to give strength. I has no Asbestos in it. Houses before 1985… 2 7216 Render your bathroom walls, two opinions versus the one, makes you wonder. 3 6096 Hi Geoff Install Puddle Flange prior to any screed. Puddle flange needs to be flush with the surface so you may need to grind away the surface to achieve this. Also as… 2 8401 |
