Hi there!
Just wondering if grout sealer is worthwhile using on new tiles? Does it help in keeping a light coloured grout from discolouring etc... Ta!
Browse Forums Bathrooms and Laundry Re: Grout Sealer. 2Mar 10, 2007 1:27 pm ![]() Hi there! Just wondering if grout sealer is worthwhile using on new tiles? Does it help in keeping a light coloured grout from discolouring etc... Ta! ![]() ![]() ![]() If all you can see are obstacles, you have lost sight of the goals Re: Grout Sealer. 3Mar 13, 2007 11:30 am ta! - we like the look of a very light grout, but it usually seems to discolour over time.
...saw some in bunnings in a spray can...would make it a bit less hassle to apply! Re: Grout Sealer. 4Apr 02, 2007 1:19 pm Hi
In my opinion, you should always seal grout as it is very porous and will absorb any spills (red wine, red cordial depending on what crowd you hang around with). It will also allow fine dust to settle into the spaces between the grout 'grains' and this is what causes the discolouring over time. I recommend using Davco (or other brand) sanitised grout as is does not contain any organic material. In a wet areas such as shower recesses you should also use Grout cure to mix the grout rather than water as it makes the finished grout impervious to water, and no water means there is nothing for mould spores to attach to. For walls you can use a product like Sure Seal aerosol to do either all the walls or just the grout. Good quality tiles with a low porosity rating do not need to be sealed but I always recommend to our customers that they seal the grout. Keep in mind that is often easier to do the whole floor as the room is empty and of course the floor is fresh and clean. Regards Bradley Specialising in 1st grade top quality tiles perfect for kitchen/bathroom renovation. Ship polished porcelain, Spanish ceramic, pebble mosaic, marble, granite, sandstone & outdoor tiles to Syd, Can, Melb, Bris, Adel & regional areas. Re: Grout Sealer. 6Apr 17, 2007 2:18 am ![]() Hi there! Just wondering if grout sealer is worthwhile using on new tiles? Does it help in keeping a light coloured grout from discolouring etc... Ta! YES, absolutely!.....that is unless you have the very best grout, EPOXY. Epoxy grout is fully waterproof and non-porous so sealing is not required. But there are many different sealers available, and they are NOT all created equal! The best family of grout sealers (in my opinion) is made by Aquamix. They even have an excellent grout colorant that is an epoxy sealer and can colour your grout any of a wide range of colours, from white to black. It can cover and colour over old grout transforming its appearance. Re: Grout Sealer. 8Apr 17, 2007 11:50 am My concern with grout sealer is that you've taken materials that will last "forever", namely tiles and grout and added a material that will need to be reapplied every few years.
(It's a bit like rendering and painting a brick house. You've converted an ultra low maintenacne item into something that needs to be reapplied every 10 years. May not sound like a big deal, but if you add 100 things in you're life that need to be addressed every 10 years you'll lose 10 weekends a year. I'm already short on weekends ![]() Re: Grout Sealer. 9Apr 18, 2007 2:19 am Hi Casa2,
I'm not quite with you with your comments there. Tiles & grout last forever? I wouldn't say that! Depending on the type of service they are exposed to, they may last a short time or a long time, and may keep looking good or become terribly stained, soiled or damaged. A good quality sealer applied properly early in the service life of a tiled surface will enhance its appearance and performance, and so lessen the maintenance requirements, giving you back some of those precious weekends! Grout is particularly porous and does often become soiled and stained. Cleaning dirty grout has typically been a most painful, tedious and unfruitful task. If a sealer can help minimise the need for restorative cleaning, then it is making life easier. There are modern efficient cleaning methods offered by professional cleaning services that make difficult DIY cleaning unneccessary, but then you have to pay for such services. Cheers! Ash. Re: Grout Sealer. 10Oct 11, 2007 1:43 pm I know this is an old post but just wondering if Vanderlay has remember his sealer for the tiles and grout as he coming closer to moving in??? Gav & Vanessa Building In Melbourne (Sth East Suburbs) http://www.arkraider.blogspot.com/ Rawdon Hill Construction - Canterbury Heritage Re: Grout Sealer. 12Oct 11, 2007 7:02 pm I can highly recommend Sure Seal. National Tiles told me to seal my pebble feature so I bought some Sure Seal and started to apply it. The pebbles sort of leaked yellow stuff which stained the grout. I freaked out and rang National Tiles who rang Sure Seal. The guy from Sure Seal had never heard of it happening before. He drove over from the other side of the city to have a look, cleaned the grout for me and took some pebbles away to be looked at. Apparently they had been wrongly stacked somewhere along the line and the yellow was the glue on the back that holds the meshy stuff on that had got onto the front of them. So even though it wasn't Sure Seal's fault, he came out again, recleaned the pebbles to be sure and then sealed them. He even left me a new spray can of Sure Seal!! I have sealed evrything I can think of! Re: Grout Sealer. 13Oct 11, 2007 7:38 pm ![]() I can highly recommend Sure Seal. National Tiles told me to seal my pebble feature so I bought some Sure Seal and started to apply it. We have a pebble feature in our ensuite and bathroom also, where did you buy the Sure Seal ? So I’ve had my bathroom renovated by a building company no more than 1-2 years ago and for the most part it’s fine but I have noticed one particular spot of grout… 0 3744 Thanks splashers, that makes sense. The waterproofing guy used this Davco product, I will raise the issue with builder and hopefully get resolved with him - if not… 2 10207 Hi everyone, Have just put a shower in the laundry and after only using it 2-3 times have noticed staining on the grout. The tiles were glued onto a concrete wall after… 0 2108 |
