Browse Forums Bathrooms and Laundry 1 Feb 19, 2009 11:57 am Re: Building on an ensuite 2Feb 23, 2009 9:41 am Hi Jeddie,
This depends on many things. What sort of structure you have, how high you are above the ground etc. Lets just assume its a brick veneer and you are at ground level. You will need to get planning permission first up, so check with your local council before you do too much more and see what is involved in that. Should not be an issue, but worth calling and just checking. The structure should be $15K or so and then there is the bathroom and ribe fit out. This depends on so many factors, but I usually say our bathrooms start at $15K and go up from there. Depends what you want to do with the wardrobe too. Just a few rails or the full fit out??? Say a budget of $40K should be in the ballpark. Does that help? Andrew Andrew Crawshaw Director Smarter Bathrooms Full Design, Build and Project Management www.smarterbathrooms.com.au Thanks for the suggestion. The space between shower and sinks was too tight. I agree about the toilet location. So I have tried two other options: The lower one is… 3 6139 the step up is 30mm and wanting it to be flat . how much does the concrete have to be lowered .we plan on removing bath and lenghten shower and adding seat. the old bath… 0 11835 |
