Browse Forums Bathrooms and Laundry 1 Feb 04, 2009 11:10 pm Can anyone recommend where to get a frameless shower screen in Sydney. I know there are a lot of places around but they either seem too cheaply made or too high end (one place asked for a deposit before even being able to provide good samples and give a quote!). I am looking for something at least mid range. Also some thicker glass seems thicker but sometimes it is the thin that seems more expensive; Which is better, thick or thin? TIA. Re: Shower screen 2Feb 11, 2009 12:56 pm Hi there,
I brought my shower screen off ebay at renovationboys. the glass is about 10 cm thick so not going to break too easily. I was so simple to put and works a treat. If at first you don't succeed, try, try again. Then quit. There's no use being a damn fool about it. W.C. Fields Brought Established. Your shower screen has failed in the way it is designed to fail with tempered glass. You could replace it with laminated safety glass but make sure it has AS standards logo on it 1 11189 You have no photo with your post. Best I can say is to remove an A&L flyscreen don't be afraid to distort the frame almost like a trapezium. It doesn't take a lot of… 1 7077 2 4498 |
