Browse Forums Bathrooms and Laundry 1 Jan 10, 2009 10:59 pm Started to pull up the tiles in my toilet to replace them as they looked like crap and the floor was uneven and found about 3 inches maybe more of very sandy cement on top of the concrete slab. I think there maybe a layer of cement over the slab as well not 100% sure until we pull up the rest of the tiles now. Does anyone have any idea what the hell this is? It looks like they raised the floor with a poorly mixed yellow sand cement mix or something.
Should we re raise the floor? or Keep it level and have a sunken toilet? Update: instead of extending the pvc drain pipe to the new level of floor they extended it with mortar. The drain pipe ended up clogged with sandy cement and mortar. The stuff around the toilet is more sandy and gets harder as it gets further away from the toilet. I think it may be water damage. The water damage hasnt spread to the walls though. Re: Sandy cement under tiles 2Jan 11, 2009 8:00 pm It is standard practice to lay a sand/cement screed over the top of a slab so as to have the floor 'fall' to the waste outlet. It sounds like it was down poorly, with way too much sand in the mix Re: Sandy cement under tiles 3Jan 12, 2009 9:37 pm It appears the bedding mix of sand and cement is too weak. ur best removing wc etc removing the tiles, bedding mix back to the original hard surface....the concrete, relay the tiles with a new bedding mix and then refit the pan. Re: Sandy cement under tiles 4Jan 13, 2009 10:37 pm vvs mand It appears the bedding mix of sand and cement is too weak. ur best removing wc etc removing the tiles, bedding mix back to the original hard surface....the concrete, relay the tiles with a new bedding mix and then refit the pan. thats what we did thanks guys for your help Hi, Currently building, we are on a sloping block so we have from floor level to the roof in axon cladding. Below floor level to the ground I want to put brick facings /… 0 4494 looks experimental to me, reinforced screed would be a better option or even better insulate between ground and structural slab. I would not put granite over that,… 3 4999 DIY, Home Maintenance & Repair All my inside walls are Fibre Cement & House has Steel frames... Tricky when one wants to hang pictures or do Wainscoating Paneling up the hallway. Those little nail… 0 3160 |
