Browse Forums Bathrooms and Laundry 1 Jan 07, 2009 11:11 pm I'm at the start of my bathroom renovation and I have designed a fairly small rectangular shower base that's about to have waterproofing done. I've been told the only way to have a shower recess in my flat is to have a step to enter the shower recess area, it needs to be on an upper level due to the set up of the sewerage system in the block. Has anyone had to do something similar? Re: Shower Recess 2Jan 10, 2009 7:49 am I take it your flat is 2 levels? And you are trying to put this on the lower level?
Is there any plumbing at the base of this proposed shower? Some photo's would be good... Electrical Engineer... Don't hold that against me... And keen owner builder... Mainly the building part!! Re: Shower Recess 3Jan 11, 2009 9:08 pm If you are on an upper floor, the problem with having a walkthrough shower with no step is that there is no way for the waste to get connected as the plumber will have no access underneath. Also, to get the fall to the waste they need to build it up rather than cut into your floor. Built with Bentley homes in Doreen All moved in Dec 2009 Now for the garden! Our stuff so far viewtopic.php?f=31&t=16532 I'll look into different shower heads and ask the plumber about some engineering and see what he says. Thanks 2 9565 Hi All, about to commence a bathroom renovation and need some advice on subfloor works. Current subfloor is hardwood T&G floorboards on 90x45 joists, but intention is to… 0 5848 |
