Browse Forums Bathrooms and Laundry 1 Jan 26, 2007 12:35 pm Hello there! I was wondering if anybody could help me with regulations regarding laundry drainage...?
I'm thinking of moving the laundry in the house, and was wondering if, in Queensland, it was compulsory to have a drain in the ground. (I'm not sure of the "proper" name) You know, basically a hole in the ground for when the water leaks/spills? If not, my whole plan is going down the drain! (no pun intended!) Byakko Re: Laundry drainage 2Jan 27, 2007 8:30 am A floor drain is not required in houses [ a class1 building ].
A waterproof membrane to the floor is required. Peter Clarkson - AusDesign Australia www.ausdesign.com.au This information is intended to provide general information only. It does not purport to be a comprehensive advice. Hi HomeOne, I'm in the midst of landscaping a cat run down the side of my house, and the recent rains have me wondering if I need to install some sort of drainage. I've… 0 12247 2 5823 I would find out how deep your clay base is and depending on the depth install a cut off drain which is more than a normal agi drain. Where the neighbouring walls is… 2 3141 |
