Browse Forums Bathrooms and Laundry 1 Oct 26, 2024 2:49 pm Hi, I am planning to add an ensuite and a powder room to our existing home, and I intend to manage the project myself instead of hiring a builder. To make room for these additions, we’re reducing the living/dining area. We’re working within a tight budget, so we’re aiming to avoid cutting into the concrete slab. One of the Solution provided by plumber is to 1. Instead of building a regular wall to enclose the area, build a Cavity wall, allowing plumbing and sewerage lines to exit the house at the nearest opening, avoiding concrete cuts and achieving the necessary 1:60 fall. 2. For shower minor cutting at the edge will be required. 3. Digging a trench to the ORG (overflow relief gully) to connect the drainage to existing sewer line and adjusting the ORG accordingly. 4. Using in-wall toilets to maintain the fall to the nearest exit point, with all toilets positioned on the plumbing wall. ============================================ Questions 1. Does running sewerage lines through the wall meet Australian standards and codes? 2. Are there any foreseeable issues with running plumbing through a wall, such as potential damage to timber framing over time due to moisture or anything? 3. Should we consider insulation around the plumbing to protect against potential leaks or any other issues? 4. What methods can we use to protect the plumbing from accidental damage, like someone driving a nail into the wall and damaging plumbing? 5. How should framing be handled? With standard 90 mm studs, would we need two frames and 110+ mm cavity between 2 frames ? or 2 studs can be joined together to create wider. depth. Thanks in advance for all the help Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: New Ensuite and Powder Room on concrete Floor 2Oct 26, 2024 5:59 pm What wall cavity has to do with sewer lines? Wall cavities are normally 40-50mm. Plumbers are not even allowed to run water pipes through wall cavities and they have to go through timber framing. I would also extend the pantry into that space, so the powder room is an L shape. Can you show a bit more of what the pantry area looks like? I had similar on my design… 2 12588 I'd be very wary of such a product. Aluminium can be prone to corrosion, powder coating will fail if not done perfectly and warranties mean nothing in most cases. Will the… 1 6454 Hi All, I'm planning on doing a minor renovation to my apartment in the City of Sydney. The apartment has an unusual multi-level layout with a large void over the living… 0 8103 |
