Browse Forums Bathrooms and Laundry 1 Aug 15, 2024 10:21 am Hi, I am trying to figure out how to fix this shower door, I have adjusted the door and as best I can tell it is in straight. If you look at the pictures you can see the same / similar gap at the top and bottom, the middle metal bit where the rubber strip goes seems to bow a bit? Any advice appreciated! Thanks Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Why won't this shower door close? 2Aug 15, 2024 10:21 am Video can be seen here https://streamable.com/w9pjl8 Re: Why won't this shower door close? 3Aug 16, 2024 10:02 am So just had a closer look and ran my finger down the frame on the right. It starts off more pushed in and towards the centre it's further out which is where its getting stuck. How can I fix that? Did try gently hammering it back in, didn't help plus it has pop rivets in it. If it was just dripping id say washer, had a fare share of these done by plumbers being a property manager.. but if its going full blast, it could be a little more with… 1 8604 It seems to me like there just trying to cash in. Because my bench was 3500mm long they told me I needed to purchase a second slab of caeser stone, which is… 4 10258 The issue is the door is quite heavy and will be hinged off a narrow panel against the wall. You can have a flat panel of glass that runs across the narrow panel over the… 1 1149 |
