Browse Forums Bathrooms and Laundry 1 Apr 22, 2013 10:07 pm I bought the Mizu 32/40 overflow push plug from Reece and asked a plumber to install it in the vanity basin for me. He said this plug only looks good but has a tendency to leak on the bottom. He said he could provide another plug and install it for me. Has anyone heard of leakage problem with the Mizu plug? http://www.reece.com.au/bathrooms/produ ... -push-plug Re: Reece (Mizu) push plug - any leak? 3Oct 07, 2023 10:37 am They dont leak, we have half a dozen of 32mm versions. But buying the rubber seal for the pop-up cover part is impossible. After 5 years the seals hardened and started cracking. You can buy a new cover complete with the seal at Reese for $17.50 but they carry only female covers. We have male (under cover fitting). Tried to buy a set of 4 PROFORMA seals from Reese but they don't fit and black ones are poorly made. May need to replace the covers and pistons for about $20 a basin. Anyone have seen the seals that work for the Mizu 32mm pop-up? Built a 2 storey house... hebel, proctor, pvc windows, aiphone, deck roofs, louver covered patio If you make sure all taps inside and out are turned off, what does the water meter show if you leave it for a while. 2 20479 Hi all, I am hoping someone has some ideas as to what is causing my bathroom leak. The leaking appears to mainly happen when we turn the sink basins on. It takes a while… 0 5207 DIY, Home Maintenance & Repair Are you doing this with a building permit? Conversion of a non habitable room into a habitable room requires building permit. 3 17656 |
