Browse Forums Bathrooms and Laundry 1 Aug 17, 2023 9:55 am Just wondering if I start tiling at the back of my bathroom wall with full tiles and work my way out and have cut tiles at the entrance? Would I be right in doing it that way but dry fitting the tiles first to make sure I don't have a slither cut at the entrance and if I do I adjust the tiles which means I could have a cut tile at the back and also the front ? Thank you Re: Bathroom floor tile layout 2Aug 17, 2023 10:16 am The best way is to set out from the room centre, then look at the size of your cut tile at the edges, if more than half tile you are ok, if less move your starting tile half a tile across, then you will have even margins. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Bathroom floor tile layout 3Aug 18, 2023 7:19 am building-expert The best way is to set out from the room centre, then look at the size of your cut tile at the edges, if more than half tile you are ok, if less move your starting tile half a tile across, then you will have even margins. But do I have cuts at the entrance or to the rear? I figure a full tile at the entrance leading through to cut tiles at the back looks better but how then do I start at the entrance and work towards the back and then get out when done? Re: Bathroom floor tile layout 4Aug 18, 2023 9:30 am Possibly both depending on the sizing. Idea of working from the centre is that you dont have a 20mm thin tile at one end and a 400mm at the other end. A quick search on youtube will give you lots of videos on how to do it. Thanks and agreed, I was initially very suspicious that the tenant had caused this. The only thing that's throwing me is I'm getting similar cracking in the bathroom and… 4 7118 I have an investment property and tenants moved out recently. However the Property manager noticed one of the floor tiles is broken and the kitchen Island countertop is… 0 20188 This is a very tight fit, I'm not sure if you'll be able to achieve what you've described. Would you consider accessing the separate toilet from the laundry? If so maybe… 1 27862 |
