Browse Forums Bathrooms and Laundry 1 May 30, 2022 8:05 pm Hi, we have been renovating and the last room is the main bathroom. This has now been tiled but I noticed the water stop angle is no where to be seen and is also tiled over. The tradesman is the waterproofed and tiler who has told me they will provide me with a certificate for the water proofing. I asked him and he told me it’s right. I have a bad feeling it’s not. Could any one advise please and What the next steps o should take if it’s not right. If it is right well that would make me feel better about the whole thing. Thank you Photos of waterproof showing water stops. Photo of tile bed showing flush with bed Photo of the water stop angle under a tile from the doorway entry as the side tile has not been put on yet, can see the void between tile and water stop. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Water stop angle flush with tile bed 2May 30, 2022 10:28 pm Yep not the correct way in my book, you might need an expert or a written standard document though. Also pretty silly not to fill the holes in the slab before waterproofing, your bed will be soaked and mouldy The unit normally clips into a metal plate screwed to the wall, either plate is not flush, or unit not hooked in and could be hanging from the pipes partly, either might… 2 15802 Okay, then the choice is really about the build quality of the door itself which means the brand name. Sorry I can't recommend one or the other so best to rely on comments… 5 3287 Hi there, looking to have a gym in a new build. Planning to install some sort of rubber mat flooring (on concrete) i.e. Asking the builder to not do floorboards in the gym… 0 1473 |
