Browse Forums Bathrooms and Laundry 1 May 03, 2022 7:19 pm Re: Bathroom layout 2May 23, 2022 11:21 pm It looks a bit tight, but 750mm wide for shower is ok. It's quite common size in older houses. Possibly both depending on the sizing. Idea of working from the centre is that you dont have a 20mm thin tile at one end and a 400mm at the other end. A quick search on… 3 8491 Thanks for the suggestion. The space between shower and sinks was too tight. I agree about the toilet location. So I have tried two other options: The lower one is… 3 6213 You never have a fridge against wall as you’ve drawn. The doors can’t open past 90 degrees and it’s difficult and maybe impossible to remove drawers 2 16268 |
