Browse Forums Bathrooms and Laundry 1 Oct 18, 2021 10:31 pm We just moved into a new home in Melbourne (only several months old). We have a bathroom ensuite and a living area upstairs. The laundry is separated from the ensuite by a walk in wardrobe. We noticed that the laundry would steam up after a hot shower (windows steam up). Both rooms have fans in the ceilings and from inspection on the outside I can find no vents that exhaust to the outdoors. This leads me to think that they are both venting in the ceiling and below the upstairs floor and thus air is flowing between these rooms via that cavity. Is this a usual design? We have noticed odd things in other parts of the home and this screams cost cutting. Anything we should be concerned about in the long term? Re: Bathroom exhaust venting to laundry 2Oct 25, 2021 11:15 am Any extractor fan should vent to the outside especially those that service a wet room like a laundry or bathroom. The moist air needs to be expelled externally otherwise continued use could see mould start to grow in your ceiling cavity. Stewie Re: Bathroom exhaust venting to laundry 3Nov 29, 2021 10:26 pm Definitely have them both vented outside, also look at getting a dehumidifier especially during the winter months it will help to eliminate condensation and during rainy weather. I have had same ventair 2in1 383m cube dual switch fan and exhaust installed last week Not sure if it’s the best but my electrician said it is excellent 1 18542 This is a very tight fit, I'm not sure if you'll be able to achieve what you've described. Would you consider accessing the separate toilet from the laundry? If so maybe… 1 61433 ![]() Hi we are looking for some advice please? We have these Portuguese tiles through our bathroom, toilet and laundry and also a small hall that connects these rooms. We are… 0 26969 |
