Browse Forums Bathrooms and Laundry 1 Nov 03, 2021 11:15 pm Hi all, I have a hairline crack (about 15 cm long) in the shower tray (I'm guessing it's acrylic). I couldn't feel any soft spots under the shower tray, so I've drilled 2 holes at both ends to stop it spreading, and covered it with PC-11 epoxy paste. It looked like that did the job, but after about a week, the epoxy itself cracked as well. I was trying a fibreglass repair kit on it, and if that doesn't work may have to get the thing replaced. Does anyone have any other solutions to try? Re: Crack in shower base 2Nov 16, 2021 3:49 pm simonjlee Hi all, I have a hairline crack (about 15 cm long) in the shower tray (I'm guessing it's acrylic). I couldn't feel any soft spots under the shower tray, so I've drilled 2 holes at both ends to stop it spreading, and covered it with PC-11 epoxy paste. It looked like that did the job, but after about a week, the epoxy itself cracked as well. I was trying a fibreglass repair kit on it, and if that doesn't work may have to get the thing replaced. Does anyone have any other solutions to try? maybe it's happening because of the poor installation I think there is a weak spot under the tray call an expert to look at it I have seen poly marble shower bases last in excess of 30 years 1 4504 Most likely poor foam installation and render installation, Joint covered with render, foam could be sitting on flashing. Do you have any render at house 4 9315 I've filled, levelled and compacted around 100mm of roadbase in preparation to lay some outdoor court tiles. Prior to doing the final compaction, I dusted the top with… 0 3044 |
