Browse Forums Bathrooms and Laundry Re: Crack in shower base 2Nov 16, 2021 3:49 pm ![]() Hi all, I have a hairline crack (about 15 cm long) in the shower tray (I'm guessing it's acrylic). I couldn't feel any soft spots under the shower tray, so I've drilled 2 holes at both ends to stop it spreading, and covered it with PC-11 epoxy paste. It looked like that did the job, but after about a week, the epoxy itself cracked as well. I was trying a fibreglass repair kit on it, and if that doesn't work may have to get the thing replaced. Does anyone have any other solutions to try? maybe it's happening because of the poor installation I think there is a weak spot under the tray call an expert to look at it Hi l had a new shower base and screen installed 2 months ago due to minor water damage on the wooden subfloor which has been… 0 7091 Most likely poor foam installation and render installation, Joint covered with render, foam could be sitting on flashing. Do you have any render at house 4 19710 Is the crack going through the bricks? as it looks like it’s a render shrinkage crack. 2 7701 |
