Browse Forums Bathrooms and Laundry 1 Sep 04, 2021 12:25 pm I have this laminate splashback stuck to the bathroom wall. how on earth can I remove it? we've tried everything and it won't budge. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ It's not plasterboard but villaboard or blueboard so I really don't want to cut the piece out as it is a hassle to have it replaced. I'm putting in a new vanity and need this gone! Re: how to remove laminate splashback 2Sep 04, 2021 12:52 pm It will just be stuck on. You may end up damaging the sheeting to get it off. I'd drive a chisel in behind it to start and release the adhesive then slowly work your way along. If you lever on a stud and use a block so you don't dig into the sheeting is you best option. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 5943 the step up is 30mm and wanting it to be flat . how much does the concrete have to be lowered .we plan on removing bath and lenghten shower and adding seat. the old bath… 0 11835 You have no photo with your post. Best I can say is to remove an A&L flyscreen don't be afraid to distort the frame almost like a trapezium. It doesn't take a lot of… 1 7071 |
