Browse Forums Bathrooms and Laundry 1 Aug 25, 2021 10:05 pm Good evening everyone, We have recently moved into our newly built house. During a walk through we identified the area around the toilet had not been tiled correctly. Basically they had cut the tiles square around a round pipe. The builders solution was they filled the exposed area with grout. Is this a satisfactory finish? Is there a maximum amount of area grout can cover? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Tile filled with grout 3Aug 29, 2021 8:07 pm Pulse most modern pans cover the pan collar fitting, maybe they expected that We are coming upto our 3 month defect period. Would this be considered a defect? This was completed after the toilet was installed. 2 5468 Thanks splashers, that makes sense. The waterproofing guy used this Davco product, I will raise the issue with builder and hopefully get resolved with him - if not… 2 12879 Hi everyone, Have just put a shower in the laundry and after only using it 2-3 times have noticed staining on the grout. The tiles were glued onto a concrete wall after… 0 5447 |
