Browse Forums Bathrooms and Laundry 1 Jan 10, 2021 9:23 am Hi over the past couple year l has noticed slight creaking noise on acrylic shower base , l guess there was slight movement, today l noticed a 10cm hairline crack . Can l get the crack repaired or do l need the whole shower removed and replaced. If l get the crack repaired and filled in would that just be a temporary fix if theres slight movement in the base or is it possible l might not get any more cracks in the future . How much would a new shower cost . l know a skilled handyman could a skilled handyman remove and replace a shower or do a need a builder or plumber which l guess would cost more. also would an insurance claim most likely fail? Hi All, about to commence a bathroom renovation and need some advice on subfloor works. Current subfloor is hardwood T&G floorboards on 90x45 joists, but intention is to… 0 5853 I have seen poly marble shower bases last in excess of 30 years 1 4517 Most likely poor foam installation and render installation, Joint covered with render, foam could be sitting on flashing. Do you have any render at house 4 9317 |
