Browse Forums Bathrooms and Laundry 1 Sep 06, 2020 12:39 am Hi all! My builder has an option for recessed shaving/medicine cabinet however I was hoping for a different medicine cabinet type that they dont offer - I was wondering if anyone knew if it is possible for them to just do a provision for the cabinet for as long as we provide the dimensions.. and we can just install ourselves after handover? Re: Recessed Shaving/Medicine Cabinet after handover 2Sep 06, 2020 8:06 am ask them to adjust the framing to suit and either plaster straight over,, that you can cut out later or frame 20mm larger and line with square set plasterboard similar to shower recess that you can drop straight into hope its not a loadbearing wall or it will get complicated Re: Recessed Shaving/Medicine Cabinet after handover 3Sep 06, 2020 11:18 am aussieta ask them to adjust the framing to suit and either plaster straight over,, that you can cut out later or frame 20mm larger and line with square set plasterboard similar to shower recess that you can drop straight into hope its not a loadbearing wall or it will get complicated Thanks so much for the advice!! We have asked for a quote for recessing the shaving cabinet they provide. Will see what they say. If they say yes, I am assuming they should be to do what you have advices above? Thansk again!!! Re: Recessed Shaving/Medicine Cabinet after handover 4Sep 06, 2020 11:46 am Most builders will charge for a variation. Ask, don't get caught out. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Recessed Shaving/Medicine Cabinet after handover 5Sep 07, 2020 12:23 am SaveH2O Most builders will charge for a variation. Ask, don't get caught out. Thanks sir! we are still in the process of colour selection ! Re: Recessed Shaving/Medicine Cabinet after handover 6Sep 07, 2020 6:38 am Curious to know. Is it possible to replace existing mirror with shaving cabinet? We have tiles floor to ceiling. Would it be difficult to remove existing mirror from the tiles? I do have photos of the stud and measurements in between as I have taken photos of these during frame stage. yes it does, you've just not understood it. theres a difference. 4 5333 Your house should come in "as new" condition. It should be clean, and without stains 1 4566 |
