Browse Forums Bathrooms and Laundry 1 Jan 17, 2022 1:15 pm Hi all, we have a two story house and the plumber has detected moisture under the tiles through grout issues so we will look to get that replaced but infrared camera shows water leaks from shower screen corner. Can anyone recommend the sequence in which we should do the grout work compared to shower screen replacement? And does shower screen really need to be replaced for water leaks from screen corner? Is there any chance at having builder fix this as they are telling us it’s not covered cause we are just over 6 years? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hi all, I am hoping someone has some ideas as to what is causing my bathroom leak. The leaking appears to mainly happen when we turn the sink basins on. It takes a while… 0 5076 If you make sure all taps inside and out are turned off, what does the water meter show if you leave it for a while. 2 20233 DIY, Home Maintenance & Repair Are you doing this with a building permit? Conversion of a non habitable room into a habitable room requires building permit. 3 17311 |
