Browse Forums Bathrooms and Laundry 1 Nov 28, 2021 11:00 pm Hi, my hot water system (50L Dux Proflo) has an ECV (expansion control valve) that was fitted in 2019, ever since then it drips pretty much after every shower or usage of the hot water, now normally this wouldn't be an issue but the system is in an interior cupboard which means the constant addition of moisture to the air is helping mould grow in the cupboard and give the cupboard that hot musty smell. The place I live at has high water pressure so should I look at turning the non return isolating valve down a bit to reduce the amount of water going into the system and hopefully reduce the frequency of the dripping? would that help at all? thanks in advance Re: Hot Water ECV keeps dripping 2Jan 04, 2022 9:51 pm The water tank is a pressure vessel! A 50ltr hottie doesn't have much storage, roughly a 10 minute shower. The unit has a thermostat that once the temp drops to a set level it starts to heat the water. Water expands as it is heated, this is where the expansion valve comes into play. Without the expansion valve the pressure would increase and over time the tank would develop a leak! If it's in a cupboard you could install a snap on vent to the door which would help reduce the humidity. We are Expert Consultant's, and we are here to help. Get some long brass machine screws and bolt right through the gate and put brass acorn nuts and washers on the other side. It will never come off 1 9074 the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 13651 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20224 |
