Browse Forums Bathrooms and Laundry Re: Capped water point unusual cost ($5000) 16Jun 06, 2021 10:45 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Capped water point unusual cost ($5000) 18Aug 27, 2021 6:05 pm I didn't proceed with the proposal from builder as it seemed unreasonable the dumbest part was builder had their own line of toilet suite with built in automatic bidet seats that did not require any such rpzd value solution. It's just that they quoted premium price for the upgrade from standard. When I asked why their own would not require rpzd value, they said its because they are doing the installation and all points will be terminated at the connection point for the suite. I did arrange for a garden tap just outside the exterier wall of where master room toilet is so when I decide I want to upgrade I can ask plumber's help to do a pass through point from there. good luck. Re: Capped water point unusual cost ($5000) 19Aug 27, 2021 6:22 pm Gees...WOW at some of the tricks these builders try to play. Good on you for rejecting their ridiculous 'solution'. That is some great out of the box thinking in getting an external garden tap opposite the ensuite toilet! Lucky your house layout was such that this was possible. Not so lucky for me as two of the toilets are behind internal walls. Cheers Re: Capped water point unusual cost ($5000) 20Aug 29, 2021 10:44 am Any Bidet or hand held shower hose in baths should have RPZ valves fitted by law to comply. The bidet shop dont always tell you all the info as they want to sell products but if you check with plumber or regulations yourself you will find you are obligated to install the valve. The water company that feeds your home will also need to be notified as if there are any issues with the mains and you dont comply it can be hefty fines. The valves can be retrofitted either beside the toilet or on the external wall outside the toilet if applicable so it protects the rest of the house as nobody wants particles coming out of their kitchen taps. If the nozzle of the bidet spray goes below the top rim of toilet bowl than cross contamination will occur, hence the need for these valves. You can put one on the mains at the front but that is only protecting the mains and your neighbours its not protecting your house. The are strict rules n regs on bidets for a very good reason to stop cross contamination in the home Hi all, Our boundary perimeter fences need replacing (3 sides). From everyone's experience, what would you install? Timber lapped and capped OR colorbond? Thank you. 0 2925 Just to makea point about this, an approach that some people have found sucessful in negotiating these rises down, Is to provide some workings to the builder, specifying… 4 81785 Building Standards; Getting It Right! Hi All, We have a fall from road to garage front. But we cannot put a drain/grate because no discharge point put by the builder. Now they complain not enough space for… 0 9270 |
