Browse Forums Bathrooms and Laundry 1 Jun 15, 2021 2:36 pm Hey guys I'm helping my son build a small bathroom between 2 bedrooms upstairs in his terrace house. It will be about 3m long x 1.4m wide. Will build a timber frame wall then FC sheet and tile with a dwarf wall running behind vanity and toilet. The joists conveniently run towards window of bedroom and I was hoping to run plumbing in that direction then out the wall. Question is the height of joists are approx 190mm high and plumber over the phone said we need 260mm of height. Is there any compact approved solution that will work here? Re: Compact floor waste trap 2Jun 15, 2021 3:25 pm Vinidex do one and so do plastec. They are around the 197-199mm high though so still may be too much for you. https://www.vinidex.com.au/products/%C2 ... oss-gully/ Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 If you have a floor waste, turn on your sink and put your ear down to the central floor waste and listen. If you can hear water running then they all connect there. If you… 10 12603 CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 17634 isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 18305 |
