Browse Forums Heating, Cooling & Insulation 1 May 19, 2020 4:50 pm so last night my daughter tells me the instantaneous hot water is not hot suspecting the pilot light has gone out, but no still lit, turn on hot water in laundry full boar burner lights up but not as strong as usual, nice blue colour, water is tepid then check gas log fire, similar story, works, but flames not as big as normal call gas department they send a tech out he opens the outlet pipe from the meter and says the gas flow sounds normal just to be sure he fits a new meter and regulator but no change the tech said meter is not big enough for 100 metre run to house, but it has worked fine for 30 years any ideas have a gas plumber coming out in the morning, but he sounded a bit stumped over the phone Re: weak natural gas 2May 20, 2020 6:27 pm for anybody following along gas plumber came out he tested everything and came to conclusion that hws and gas log had both developed a similar fault at the same time fitted a new instantaneous hws and hot water is all fixed will have to get tech to service gas log heater Hi, planning on using the attached stone pieces in my bathroom. I want to remove stains and gloss seal. Can I get some advice on best way to remove stains and best… 0 6700 4 10817 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20220 |
