Browse Forums Heating, Cooling & Insulation Re: Underfloor insulation 7May 29, 2020 11:18 am Stewie D How did you fix it in place? Stewie I used Bradford optimo underfloor. It comes with plastic saddles that hold batts in place (i have steel floor) Re: Underfloor insulation 8May 29, 2020 12:35 pm I'm just curious to the methods other guys use. When we did renos for clients we retro fitted under floor insulation to maybe 6-7 homes. We've used everything from battens nailed across the joists to chicken wire to proper fittings recommended by the manufacturers and just staples. Not too bad if you have a bit of headroom but otherwise a right royal pain in the butt. Stewie 1 10131 Hey guys building a new place through a volume builder and just wondering if i should complain to the site supervisor as we just had plasterboard installed. Looks like… 0 11273 1000000% definitely add insulation. I have in my home and it makes a big difference minimising sound transfer. Insulation is pretty cheap and definitely worth it 2 6191 |
