Browse Forums Heating, Cooling & Insulation 1 Sep 02, 2019 8:37 pm I am in need of expertise, apologies if its unconventional. I have found a rental to move into and the agent is convinced it only has ducted heating on the ground floor and ducted aircon on the top floor. Does that make any sense and could it work? Sorry I don't have much more info other than the house is 5 years old 3 beds upstairs. Re: Could aircon on first floor only work for the whole hous 2Sep 05, 2019 10:32 pm The short answer is no it won't work. It is likely air conditioning was only put upstairs as heat rises essentially and the bedrooms upstairs would be unbearable in summer. Re: Could aircon on first floor only work for the whole hous 3Sep 06, 2019 7:08 am I think it would probably work. Aircon with cold air for the summer, cooling upstairs and falling down to the lower floors. Winter, the heat would rise to the upper floor. It would also depend on the size of the unit and insulation within the building frame. Re: Could aircon on first floor only work for the whole hous 4Sep 07, 2019 8:55 pm Air condition will not work like this. If it's located on the first floor it would be comfortable only there. I recommend you to change conditioning system. For exampke humidity monitors or ciculating fans like honeywell. Anyway check reviews https://cozyhousetoday.com/honeywell-ht900-vs-honeywell-ht908/ The unit normally clips into a metal plate screwed to the wall, either plate is not flush, or unit not hooked in and could be hanging from the pipes partly, either might… 2 15772 retail its around double the price of a similar sized actron/dakin system from memory, They are excellent systems though. But with how builder gouge on AC/heating, you… 4 13695 isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 17501 |
