Browse Forums Heating, Cooling & Insulation 1 Jul 28, 2019 12:50 pm Hi, I have a new Kaden gas ducted heating system (KA3) which has stopped working. I have removed the cover from the actual ducted heating unit to look at the control board as it has a LCD screen built into the circuit board which displays messages. It states "Error - Press RESET" However I have no idea where the RESET button is. I am using a Kaden programmable wall control unit with this heater. Does anyone know how to reset the unit from either the ducted heating unit itself or how to from the wall controller? I have tried the obvious resets - turning the power off, taking the batteries out of the control unit etc etc. Many thanks in advance. Re: Freeeezing! Help! 3Jul 28, 2019 1:26 pm arcadelt Peter3140 Does anyone know how to reset the unit from either the ducted heating unit itself or how to from the wall controller? What does the manual say? The manual only has "Reset" instructions when using a Kaden Networker Control, not a Programmable Wall Control unit. Freeeezing! Help! 4Jul 28, 2019 1:53 pm Peter3140 The manual only has "Reset" instructions when using a Kaden Networker Control, not a Programmable Wall Control unit. Do you have the manual for the Programmable Wall Control, or is it available online? Re: Freeeezing! Help! 5Sep 25, 2019 1:04 pm arcadelt Peter3140 The manual only has "Reset" instructions when using a Kaden Networker Control, not a Programmable Wall Control unit. Do you have the manual for the Programmable Wall Control, or is it available online? Hi there, you can find the manual online here: https://www.reece.com.au/assets/brands/ ... ide-V1.pdf There is a section on the wall control. Yes, unless you are in a low intensity rainfall area or the area is protected from rain. Do you have access to NCC Part 2 or can you download it? I can email you a copy… 10 12916 Thankyou so much 😀 I've decided on White on white for doors and trims, White on white 50% on ceiling and Mt buller for walls. Fingers crossed it will look OK 😀 2 7602 brokers will also be in a position to get you a better rate than the advertised rate most times. 6 7854 |
