Browse Forums Heating, Cooling & Insulation 1 Jun 09, 2019 6:16 pm Hi all, Our house has a solar hot water system on the roof. As a family of 4, we often run out of hot water, particularly in the winter months. The system has a boost setting which i can set the time of day for it to come on. Can anyone advise what sort of schedule should i set on the timer? Currently, I have it set for a few hours in the morning before we wake, and a few hours in the afternoon before showers/baths etc.. Thanks in advance! Justin 4 6834 the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 14076 instantaneous is three phase and draws heaps of current, the efficiency comes from not storing it so you don’t lose heat to the environment. The problem is it is not… 5 1493 |
