Hi
Would rendering brick walls help with insulation
Heat cold etc
Thanks
Browse Forums Heating, Cooling & Insulation Re: Rendering brick veneer home 4Jan 28, 2019 5:06 pm arcadelt You could, however, have insulated cladding added, and then depending on the type, paint or render for a new look. Hi Thanks I’m trying to achieve a bit extra noise insulation as well Would the cladding help with that ? Re: Rendering brick veneer home 5Jan 28, 2019 5:14 pm It should help a little bit, but keep in mind that your windows & doors will still be acting as "the weakest link". If you want to improve noise insulation, think more about internal solutions as they are generally more effective and much cheaper, e.g. double + thicker plasterboard placed on sound clips & furring channels, ideally with Green Glue applied between them will help to achieve STC values of up to 60 and higher. Brass fly wire, you will need to cut it, shape it and jam it into brick slots 1 7421 2 8293 can’t tell from the photo, a tie down rod will be 12mm, is it a steel beam? he should be able to work it out 1 4419 |
